Don't forget to chage the caliper guide pins. under extreme heat generated by breaks metal expands and contracts so for the naked eye you can't tell if they are bad or not. I work at autozone and picked up at set for both sides for about 12.00. This will help prevent uneven pad wear
Thanks guys.
I looked at the tech folder but didn't find it on the first go round but I found it now.
One question...how important is it to replace the guide pins? and is the silicone grease they reccomend using available at Advanced Auto or similar place?
I replaced my pads and rotors all the way around at about 85K. I had to take them back off due to intense squeeking caused by the pins under a load. I ended up damaging one of the calipers during removal with new pads because everything is so tight. Its worth the time and effort saved for 12.00 bucks.
I have used a real fine film of anti-sieze on brake guide pins. It worked good and doesn't attact dirt. Apply to pin and then wipe off. Fine is the word here.
I just changed mine this weekend. One of the lower pins was frozen in the caliper bracket. It look about two hours to remove the pin. Make sure you grease the pins with high temp grease. Its not a bad idea to replace the pins and especially the boots.
I would also suggest greasing the side clalipers as well as they can also make load nioise if they get any corosion between them and the backside of the pad. They sell small grease packets just for that at O'Riellys here in Texas but must have something similiar there too . . .
