Guys with the upgraded slide pins...
How freely did they move when you installed them? The one without the rubber tip is great but the one with the tip takes some umph to move. Is this normal?? The bores are polished shiny (used a scotch brite pad attached to a drill), but the bottom hole on both sides is still slightly pitted cause they were both corroded. I gotta get this back together tonight don't wanna do something that will damaged the new pads or rotors. HELP!
Good to know. I'm gonna clean em up real good and put everything back together then.
sorry i dont have any info but this is what i can offer
Welcome to guzzle's Front Caliper Slide Pin Upgrade Web
hes on here somewhere..
i will be doing this too soon. i am dragging brakes in the front and its affecting my mpg..
1 thing at a time
sorry for the o/t rant
1 thing at a time
On the one new slide pin that goes in the bottom hole. Welcome to guzzle's Front Caliper Slide Pin Upgrade Web
PaysonPSD
07-12-2012 08:02 PM
LSUtigers
03-23-2007 01:25 PM
bretts3504x4
08-28-2006 05:21 PM
