Driver's seat and brake pedal wont adjust??
Yesterday my wife used my 2002 Excursion and had to adjust the seat and brake pedal for her comfort. Now the seat or the pedal not work any longer. The seat memory buttons on the door don't work and the electric seat adjusting switch on the seat doesn't move the seat either. Also the brake pedal adjustment switch doesnt work either. I checked the owners guide to see try to fugure out which fuse may have blown; I didn't find any fuse labled electric seat? I did find fuse #1 was for adjustable pedals, and checked it to see it wasn't blown. I kept checking and checked fuse #15 "Drivers seat module memory", checked fuse # 29 "customer access" and those fuses are fine.
Does anyone have any insight or suggestions as to what's wrong and how to fix my adjustable driver's seat and brake pedal??
Mine does that as well, but only once and a while. I have found if I stick my hand under the seat and wiggle the wires the seat and pedals will work again. I haven't explored it because it's not very often it happens. The first time it happened we were away from home camping and my wife went somewhere which meant the seat was all the way up. I went to get gas the night before our trek home and the seat wouldn't move. I was like "crap", I didn't want to drive all the way home pulling the trailer hugging the steering wheel. That time I waited until morning and they worked again. I thing in all, it has only happened 3-4 times. The seat and pedals rarely move because she doesn't drive it much. I assume there is a loose wire or connector under the seat.
Anyone know of a permanent fix for this? My search on this site has revealed others w/ same problem, but no one w/ the "Ah HA!" in identifying the culprit problem (like, for instance, it sounds like it is not a fuse problem, nor a motor problem; appears to be traceable to either some "wire connectors" under the seat that need attention or possibly the "seat memory module"--which actually makes more since as it's the single place where both the seat and the pedal systems (with their separate motors, etc).
I'm considering buying a 2002 Ex w/ this problem, and am trying to figure out how much allowance I should ask the seller in the selling price to factor this in.
I'll post back if I find anything out on further searches (or if I buy the Ex and get it fixed).
dave
dave
Ok. Did more searching. Found the following posts that may be helpful for Driver's Pedal/Seat/Memory adjustment problem (looks like it has to do w/ a corroding 'orange wire w/ green stripe' under the seat):
https://www.ford-trucks.com/forums/8...dont-work.html
https://www.ford-trucks.com/forums/6...h-seats-2.html
I'm a total newbie and I'm clueless how to fix this problem myself...Can I just take this info into my dealer (or another shop?? would that be cheaper??) and tell them to try this solution?
Thoughts? Thanks in advance. dave
I have F350 2008 6.4 power stroke diesel Lariat trim super cab with memory seat
My driver's seat and pedal won't adjust.
The common solution on youtube will not for this truck at all, as it only works for F150
I checked all the cable/wire, YES, I could get 12V out of the green&orange cable
replace seat control module, switch will not solve the problem
In the end, it is a pink fuse blown in the engine bay.
LOL
LOL
