V-10 Availability
V-10 Availability
Some have been posting that people are being told they can no longer find V-10's from Ford. Maybe they are getting this due to the new V-8 replacement for the V-10. I thought Fred Jones co. was rebuilding the V-10 for Ford. I am thinking the V-10 will be available for many years as there are so many in use. What say you?
New nonrefurbished v10 2V motors are still available from ford. Part # 9c2z6006aa
2019 E-350 cutaway still comes with a 2V 6.8L V10
https://www.ford.com/commercial-truc...ipped-chassis/
https://parts.autonationfordwhitebea...ine-9c2z6006aa
Even if they do pull the V10 from the line up, chances are high that they will support the V10 for at least the next five to ten years. AFTER THAT TIME PERIOD, the supply lines will probably dry up. That is a LONG time from now.
I just picked up a 2016 V10 2v that came out of a wrecked (rolled) E450 Class C motor home with 4300 miles on it. I'm swapping it into my 05 Excursion that has a V10 in it.
There are a LOT of engines out there, both new and reman... I doubt Ford will just ditch that thriving business until they build up the new 7.3L V8 support and service and cross their fingers that the NEW 7.3L will find the same following as the old 7.3L diesel. Time will tell us that tale in the coming years.
HOPEFULLY it's not a badly designed V8. That would be problematic.
BTW their site has a lot of links and info via .PDF's that might prove helpful or interesting to those of us with V10 or V8 Modular Motors especially if you're doing an installation and want to keep the warranty intact.
Ford Service Department refuse to do an Engine swap on my 2002 Excursion. Manager said they could not get crate motors for my SUV. So far, Jasper is doing a standard crate motor for me. Lead time 3 weeks. https://www.jasperengines.com/crate-engines
Have a fine day and a better tomorrow,
Jack
Jack
BlueOval5.0
Modular V10 (6.8l)
07-20-2006 01:56 PM
