Strongest (not prettiest) tie-downs - homemade or aftermkt
I searched the forums, but didnt find much info, so here goes.
I have tried stake post tie downs, and ruined my poor '78 bed rails, ripping the post holes up.
I need something to tie HEAVY stuff down - not a bag of Cheetos.
So, throw in some links and tell me what HEAVY DUTY tie downs you are happy with - even if you have had to bolt them to the SIDES of the bed.
And if you have homemade ones that work - post some pics and info, plz.
Thanks!
Thanks!
What?, Ya plan on drag racing with that HEAVY stuff? haha. I've had many trucks, and I have never had any problem with the stock tie-downs, The ones in the bed, or the stake pockets. I'm usually a very conservative driver when I have a load. and even more so, if I have a trailer.
What is this HEAVY stuff you mention? I find the heavy stuff stays in place better anyhow..... It the light crap that tends to need tied down to keep the wind from shifting it.
I dont even remember what load it was in my '78 that started to tear out the pockets. I've hauled bricks, appliances, motorcycles, and just junk. I just didnt want to tear out the stake posts on the 02 I just got.
And y, have a trailer for heavy stuff, but I put D rings on it and I could weld to it b/c it's heavy steel, not the light crap on trucks now.
Rediranch_too,
There are guys on here who have hauled just about anything you can think of with their trucks. Next time you have to put something heavy in the the bed, put a specific post up about it and we will be glad to help you devise a way to haul it in a safe and secure manner. Without knowing more about what you are trying to "tie down" we can't help you too much.
My father has a '95 F-350 and to solve the problem of not having lower tie downs he simply drilled a hole in the corners and put heavy duty eye bolts supported by nuts and washer on the inside and outside of the steel. I'll post some pictures later or tomorrow.
Sorry if the pics aren't the greatest but I hope they help.
I think he is looking to create a hard-point for the tie downs.
This is our approach, we added a piece of channel bolted to the frame with Grade 8 bolts replacing the front bed bolts.
The rear bed bolts hold a piece of hardened steel drilled with a couple of holes on either side. During the summer, these hold a couple of Grade 8 D rings.
This setup has held everything from rolling equipment, a loaded salt spreader and even palletized salt without tearing, straining, or moving.
