not far at all from you. i plan on doing a 3 inch drop in the front and dropping the rear also. not sure if i will go witha suede look or a base coat clear coat look. but i have time to make that decision this winter for now i plan on enjoying it this summer
Good plan, but I would go ahead and do a shiny job on it because a true suede is a base coat, clear coat but with a flattner in the clear. (Little more expensive to do it right) But thats just my 2 cents worth. If you are looking for some local shows to go to check out Indiana Car Shows
