2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
PATS No Start Condition - HELP!
Old 04-08-2010, 10:18 AM
ParisDakar's Avatar
ParisDakar
ParisDakar is offline
1997 Expedition, 147K. Pulled in the driveway and the engine quit. Engine will crank but won't start. When you go key on, the THEFT light goes on for 2 seconds, then flashes fast for 1 minute, then flashes code 16. Neither key will start it. I can't seem to connect with my OBDII reader. There is a single wire going to a clip (broken) that holds a contact into the lock cylinder, but that just sounds the key in chime. Can anyone help troubleshoot this? I'm about the replace the PATS transponder, assuming power and ground checks out. The only other option I have is to have it towed to the dealer and bend over. Thanks.
Old 04-08-2010, 10:51 AM
berry1234's Avatar
berry1234
berry1234 is offline
Wrong section. This is 07 and up.
Old 04-09-2010, 08:58 PM
ParisDakar's Avatar
ParisDakar
Yup. I realized that and put it in the other section. Thanks.
dchamberlain
1997 - 2003 F150
50
04-27-2019 10:59 AM
mommyoftwo
2004 - 2008 F150
12-17-2014 06:19 AM
Lemming
Electrical Systems/Wiring
08-28-2014 02:55 PM
BeachEx
05-21-2014 05:29 AM
Jesser02EX
02-23-2014 01:00 PM
Quick Reply: PATS No Start Condition - HELP!
