Sponsored by: Real Truck
checking auto trans fluid ?
Old Apr 7, 2010 | 09:51 AM
JST2CRZY's Avatar
JST2CRZY
On my 01 Diesel auto I noticed a leak coming from the front of the tranny. The fluid level was approx 1 inch over the full mark when the truck was cold and not running. Two dealers have told me this is normal. Thoughts?
Thanks, Bill
Old Apr 7, 2010 | 10:29 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Look at your owners manual on how to check the fluid level. Drive the vehicle to normal operating temp. Put tranny in park or neutral (Set brake). NOW check the fluid level. Remove stick. wipe with clean rag, re-insert stick, remove and check.
Old Apr 7, 2010 | 10:44 AM
Kajtek1's Avatar
Kajtek1
Ditto on checking the fluid on hot and running transmission. Do it after at least 1/2 hr trip.
BTW avoid those dealers in the future.
Old Apr 7, 2010 | 11:52 AM
GUNNERDOG's Avatar
GUNNERDOG
You might have to climb up under the truck to see where the leak is coming from. I just replaced my cooler lines because they spontaneously started leaking.
Jermafenser
Oil & Lubrication
20
Mar 21, 2010 08:42 PM
aircargoo
Nov 10, 2009 10:00 AM
91 blowncoupe
Jul 22, 2008 06:16 PM
captain p4
1997 - 2003 F150
Jun 4, 2005 07:19 PM
mtgrzlyman
Sep 6, 2003 09:04 PM
