How can I prepare my truck for storage for about 6 months?
Exactly what the title says, I am looking at storing my F250 for about six months. What are some things I do can do to her so she won't have problems starting and running whenever I come back?
Last time I stored her, I just locked her up and she had some rough starts. I'm not too sure if that's good for her, but would like to learn more from the pros.
You in the service? I'd say lock it indoors somewhere with the batteries unhooked. I had one stolen parked outside at a friends house and another one stripped parked in what I thought was a secure storage room. Both were on base too and I got royally screwed by the insurance. It happened on a secure base and they weren't responsible so they said. The base security said the same thing though.
You really don't need to do anything other than unhhook the batteries though. If you even think there is a chance of rats or mice then put out more than enough poison under the hood, in the cab and under the truck. Squirrels too!
Just pulled mine out of storage. Been in there all winter. 5 months.. Both batteries were dead. Forgot to unhook them. I should have brought the batteries home and toss in basement so they don't freeze.. Other than dead batteries, She fired right up and brought her home. Just take care of the batteries and everything should be fine. As stated above.
If sitting outside i would be concerned about the brake rotors rusting, though. Had a car that didn't fair to well to sitting outside. The rotors were trashed and needed to be replaced.
I would prefer to drain the fuel and disconnect/remove the batteries. If you remove the batteries make sure they are placed on some sort of mat or non thermal material, batteries will discharge faster if they are on cold surfaces. If you can not drain the fuel at least treat it with a good biocide and anti gel if the weather is cold.
When it comes to re-start charge the batteries first.
Newby87
33
02-26-2016 12:35 PM
