2001 Explorer Sporttrack
Old 04-04-2010, 05:19 PM
neilx's Avatar
neilx
neilx is offline
Hi everyone! A new guy here.
I've got an issue with my sporttrack. When I turn on my truck, the voltage display drops down to low and stays that way.
I bought a OBD2 code reader and got code P1451. I know the technical description is: EVAP Control System Canister Vent Solenoid Circuit Malfunction.
I also know the possible causes and possible solutions are:
Causes
A code P1451 may mean that one or more of the following has happened:
  • VPWR circuit open
  • Damaged canister vent solenoid
  • Canister vent solenoid circuit open or shorted to ground, power, etc.
  • Damaged Powertrain Control
    Module (PCM)
Possible Solutions
  • Verify canister vent solenoid - To verify normal functioning, monitor the EVAP canister vent solenoid signal PID EVAPCV and the signal voltage (PCM control side). With the valve open, EVAPCV indicates 0% duty cycle and a voltage approximately equal to battery
    voltage. When the valve is commanded fully closed, EVAPCV indicates 100% duty cycle, and a minimum voltage drop of 4 volts is normal. Output test mode may be used to switch output on/off to verify function.
  • Replace canister vent solenoid
Now, I've copied this from the internet, so I only know this because I searched for it. I'm no mechanic, just a backyard one.
I've checked the wires for possible cracks and found none. The solenoid is a bit rusty, but all the wires are intact and as they should be.
What am I missing here? Am I looking in the wrong direction or???
Any help would be greatly appreciated.
Thanks,
Neil.
Old 04-04-2010, 08:03 PM
ncranchero's Avatar
ncranchero
ncranchero is offline
My first recommendation is to have your battery tested. Weak batteries make these Sport Tracs do all kinds of weird things!! I don't think the P1451 has anything to do with your voltage issue.
Moto Mel
1997-2006 Expedition & Navigator
08-12-2011 12:12 PM
TheInsurancePro
08-16-2010 07:37 PM
rastasj
02-05-2010 11:47 AM
tomax7
2009 - 2014 F150
10-21-2009 03:40 PM
crazychuck
13
03-03-2009 12:51 PM
Quick Reply: 2001 Explorer Sporttrack
