calling all super camper specials
#1201
My brother picks up my 1974 SCS this coming Sunday. I get to see it in a little less than a month. But I am also eye-balling a quite rusty and tired 74 SCS that had been rode hard and put away wet, but it appears to have all the miscellaneous parts that the one my brother is pickup needs and is in the same region. What are you guys seeing for pricing for a rusty bodied but has most trim and is a decent runner worth? Both trucks are 390/C-6 trucks. The three main things I want off the rusty one is the stock hubcaps, factory Ford frame mounted camper tiedowns and a decent canopy. It also has various trim pieces that my all original SCS is missing or are lightly damaged.
Thoughts?
Thanks!
Garry in Kodiak, Alaska
Thoughts?
Thanks!
#1202
Thoughts?
Thanks!
Thoughts?
Thanks!
#1204
#1205
1979:
If the block casting number is: D1VE-6015-AB or A1B or A2B = Internal balance.
If the block casting number is: D9TE-6015-AB = External balance (has a weighted crank spacer).
1979 only affects F150/350 & E250/350. 1978 was the last year that Passenger Cars were available w/a 460.
#1206
Just picked up a 73 f350 scs with, supposedly, a blown motor. The 390 2v turns over fine but won't start. May be some knocking in the bottom end while trying to start. PO stated it overheated and burnt up. Shows 65k on odometer so no telling miieage, but generally looks like someone took care of it before PO. He owned it a couple years. Rad is full, no sign of oil. Oil looks good, no milkshake. Strange. Haven't done a compression test yet, but why would an overheating episode cause low compression? I'll post photos later for you, but I'm still running my 74 f100 with a 360 2v. Considering swapping the 360 into the 73scs. Opinions? Many thanks.
#1207
ALL 1968/78 460's are internally balanced as are some 1979 460's.
1979:
1979:
#1208
1979 f350 TRAILER SPECIAL SPARE TIRE COMPARTMENT PARTS
HI, trying to find out what i am missing. i have the two saddle parts, the original mount seems to be intact on the frame, but the inside saddle part dosent seem to be wide enough to mount on the frame mount. i have a breakdown that shows a piece coming over the frame ares i.e maybe out of one of the bed supports, which seems to have a shaft running thru it, but doesnt show a parts refference. is the rear saddle supposed to bolt to both sides of the mount or just one? any help would be appreaciated. thanks. tracy
#1209
Hi, I just changed my mind. I was half way through a part out of a 76 SCSTS and might have found a good home for the frame and box but was really dragging my feet on the deal. After ready a few threads I realize this truck is as cool as I suspected. 460 and c6 need work but frame is good and box is restoreable. This wil be fun
#1212
Did Ford ever factory build SCS 4x4?
Just came back to the forum to say that my sister finally drove my SCS after it had sat for 4 months, and all is well! So I was happy to hear that.
I was surfing around You Tube and I saw a few truck-pulls that showcased some Dentside F350's that were SCS with the 140" wheel base and they were 4x4's. Just thought that I'd see if anyone knew if they were factory? Or aftermarket...
4X4 SCS
https://www.youtube.com/watch?v=9HEoD91Jyc0
4X4 SCS
#1214
#1215
