That would be me! I wondered before if you were on here, I remember talking to you and you had a great knowledge of these dents. I'll get with you when I start to part with some goods. I'm making one truck out of two and will have a handful of stuff to get rid of.
Im curious as to how the truck handled with the bias 16.5 tires before you swapped them out for radials? Too bad you weren'tcloser to Colorado, I'd maybe take those off your hands.
just wondering how many 73-77scs ,78-79f350ts, or just plain 140" wheelbase 2wd's are out in FTE land. stock ,modified or inbetween lets hear from you!!! I need ideas and inspiration
G-man, the tail lights were redesigned in '74 from serial number T80,001.
1973 F100/350 & 1974 F100/350 before serial number T80,001:
Screws retain the separate tail lamp lens to the metal body that has the socket w/wires swaged into it.
1974 F100/350 from serial number T80,001 & 1975/79 F100/350:
Tail lamp is a one piece plastic assembly, socket w/wires twists into plastic body.
These tail lamps and sockets are the same as: 1975/91 Econoline & 1978/79 Bronco. Sockets are also the same as 1971/72 & 1977 Pinto/Bobcat.
1973/79 F350's on the 140" wheelbase:
1973/76 Super Camper Special / 1973/79 Regular Cab Trailer Special / 1977/79 Regular Cab Camper Special.
