Fuel Filter Problems
Old Dec 24, 2010 | 02:12 PM
spidertoy's Avatar
spidertoy
okay, so am trying to change our fuel filter, got the lid off no problem, does the OEM filter thread into the bowl? cannot seem to get it to come out or even turn if that is the case, have been searching here for about 2 hours now, to no avail
Old Dec 24, 2010 | 02:29 PM
Izzy351's Avatar
Izzy351
No -- it just presses down on the tube. If you can turn it back & forth, pull up at the same time -- it should come out. Also check carefully for old O-rings. If it's that stuck on there, give the bowl a thorough inspection after you get it off.
Old Dec 24, 2010 | 02:38 PM
spidertoy's Avatar
spidertoy
thank you, finally got it off, and did find the old oring which I knew to check for after all my reading on here new filter is in, and truck seems much happier now
Old Dec 24, 2010 | 09:11 PM
2000ca250's Avatar
2000ca250
with the wix ones, I learned the hard way today that it is much easier to actually use a socket on the top, as it is designed instead of using pliers. I know it may be a pain to go buy a socket, but I tried using the pliers and wrench, and it started rounding off the top. Got a socket and used that, and it turned with just a little effort. Its not the best design, but its not as horrible as it seems. If used with teh socket it works pretty well
Old Dec 25, 2010 | 10:50 AM
Fat Diesel's Avatar
Fat Diesel
Believe it or not the whole bottom of the filter can separate and stay in the housing. Further disbelief was achieved when I went to pull out the bottom sheet metal and found two of em. So there is room to screw up and leave more than just an o ring in there and it still goes back together. Not sure if it was sealing and filtering at that point, but keep it in mind.
ChrisMelton78
Feb 4, 2014 11:28 PM
Buck268
Sep 30, 2012 01:29 AM
Byron Sanders
Feb 1, 2011 03:21 PM
fordtrucklover94
Dec 17, 2010 07:31 AM
704core
North Carolina Chapter
May 3, 2007 05:06 PM
