Needin' some help....
Old Apr 2, 2010 | 09:28 PM
plumber01's Avatar
plumber01
a good placew that may be cheaper is e-bay. I have seen alot there just make sure you check their feed back to see if they are 100%
Old Apr 2, 2010 | 09:35 PM
CalebJns's Avatar
CalebJns
Just to go along with what the others have already stated...as odd as it sounds I have actually had my connector go bad. took me about 2 hours to figure it out...and I was stranded at a gas station...ended up costing me like $.82 for a stinking connector. I had a buddy that stopped by with a battery tester, every time we tested the battery, it was fine, tested the alternator, it was fine, solenoid, fine...by chance I tapped the connector, and he was looking at the tester, and nothing! Sometimes it is a simple dollar fix...other times it can be super simple like a loose ground...good luck!
GT40NUT
32
Aug 30, 2014 05:40 PM
berick
Feb 15, 2014 06:28 PM
dyingtolive
Aug 1, 2012 07:37 AM
Fishin76
Jan 12, 2011 07:48 PM
hogbus
17
Oct 15, 2006 12:48 PM
