even my wife thinks something happened!!
a couple months ago i installed a new turbo wheel, 6637, ccv delete, guages, AIH delete, 4" turbo back exhaust, and had my TS teburned by tony. when i got all the mods done i reset the overhead mileage guage. ive drove about 3000 miles since and the guage as well as my calculations at the pump have always been right at 13 mpg. well since yesterday (about 120 miles) the mileage on the overhead console has gone up to 14.8 mpg. there has not been a change in driving habits or conditions. the only thing i can say is the injectors do sound a little quieter. im not complaining but i would like to know why. any ideas??
By upgrading your exhaust and intake, your truck is able to breathe better. What tune are you driving around in from Tony? I consider Tony's tunes better than the ones from TS. Several others here share the same opinion.
Of course relying on the overhead display for accurate MPG readings is not wise, especially when you have a chip that has changed the way the PCM operates. You really need to hand calculate your mileage for a true idea of what you're getting.
How do you like the power of Tony's tunes compared with TS?
sorry i didnt say but i leave it in the daily setting basically all the time. my calculations have always been within a tenth of a mile from what the console says. i like the tunes much better but its been cold and ive not had a chance to "play" much. not as much smoke as i thought, alot more before the reburn.
You need to do the math again with Tony's tunes.
I was thinkin the same thing, but didn't want to say it...not real sure if there is a change between the season with diesel...i know there's something added to gas, you can actually smell it, but i didn't know there was an additive for us...
I know they used to mix #1 with #2 to lower the gel points of diesel. #1 is kerosene I believe, #2 is diesel fuel. Straight diesel can get cloudy at around 40 degrees I believe if it has no anti-gel mixed with it. The cloudy look is wax crystals forming in the fuel that can clog a filter.
I have heard of guys mixing a gallon of gas with diesel fuel back when I was a kid. I would never recommend doing that today! Kerosene has a lower BTU than diesel which is 1 reason for the lower fuel mileage in winter. I have heard the mixture is any where from 5% to 20% kerosene, depending on where you are in the country.
