Problem - Alternator or battery?
Old Apr 1, 2010 | 10:39 AM
BCHauler's Avatar
BCHauler
I have a digital multimeter. I quickly put it on the battery yesterday with the + and - on the corresponding terminals and the dial set to 20v. The meter simply read 1. so I think I must be doing something wrong.
Old Apr 1, 2010 | 09:02 PM
rainbowATF's Avatar
rainbowATF
As stated previously, make sure your voltmeter is set up to read DC voltage, 20V scale is good. It is not a good idea to remove the positive cable while the engine is running. These alternators have a sensing wire to battery voltage. The regulator will increase output without this feedback circuit. There are numerous references to this in these forums (search). There is always someone who gets away with it and is lucky to get it to work without incident, and it was a valid procedure for the days of generators on vehicles. But you don't need 20+ volts surging to your circuits and your computer. Measure it with your voltmeter or have an auto parts store load test the battery and test the alternator on one of their in house diagnostic instruments.
Old Apr 1, 2010 | 10:11 PM
95F350XL's Avatar
95F350XL
There is nothing wrong with either, this is commin to most older stuff, I have the 130amp alt in my 88 stang, 88 bronk, and 95 F350, and when ideling with lights, wipers, radio and heat on(no ac in all lol) the bat meter goes down. The alts just cant put out the load that it needs at idle, needs the revs to make more power. I have dual batteries and the 130amp in the F350 and it does it. Its life. You are better off going to a autozone or where ever and have them put the machine on your truck, it will test the CCA(cold cranking amps) off the battery, whats its rated for, and what it really has, will also tell you the % of life and charge of the batter. That tool can also test the alt, volts with load on and load off, idle and revs. We have an awesome 1 at our job.
Old Apr 21, 2010 | 12:51 PM
pisces74ca's Avatar
pisces74ca
going to try a load test...
thanks... will post results this what seems like lack of power for such a simple task is driving me crazy, never mind my mechanic.
keeps continuing and I will need to re-think keeping my flareside.
Old Apr 21, 2010 | 02:36 PM
BCHauler's Avatar
BCHauler
As an update, had the battery tested and it's fine. Found a sale date on it and it's only 2years old. Going to upgrade the alt and replace the positive battery cable.
Chris Gathof
1983 - 2012 Ranger & B-Series
Oct 27, 2015 10:04 AM
KDAVID1
Feb 19, 2015 08:04 PM
abrown3mtg
Feb 6, 2015 03:59 PM
mattcad
40
Jul 17, 2013 11:02 AM
SuperDutyScaler
Jul 14, 2010 12:11 PM
