Low fuel mileage mpg?
Guys, I have a 86 f250 6.9 with a c6 and 4.10 rear end (i'm guessing its a 410 since I run 2800 rpms at 60mph). i have 265/75/16 tires.
I am only getting 11 - 12 mpg with no towing or loads. Is this expected or is it low? what should I be getting and how do I improve with a stock setup? (not interested in turbos, ram airs, etc.)
Thanks.
Thanks.
on
how many miles on the engine?
how many miles on the ip and injectors?
around 2600 rpm probably right?
anywho.nope,not normal.very low.unless your in hill valley and city driven all the time.even then,while empty you should do better empty than a 460 gas job lol.
man,that's really revving.have you considered a 3.55 gear swap?
either that or id consider slowing down to at least 2k rpm,but that's only 46 mph in your case.
3.55's would bring you down to about 2200 rpm @ 60 which be much better.
is this a 2wd truck? do you tow big loads often? if yes 2wd,and no not hauling much,then 3.55 rear end swap is easy and reasonably priced to do yourself.
edit,
yeah,getting an OD trans like Franklin suggests though much more $ and work,would for sure help too.gear her up to 3.55 and OD,and you wont ever look back.
Franklin's MPG gain could have been much better without those 12.50" wide tires too (though the 35" geared his 4:10's up.)-oh nm that one,he had the same tires he started with.so = gain.
Franklin,
where's your garage man.
-oh cool.i found your gallery.
edit,
Franklin,
on
Thanks.
Thanks.
Your only real choice short of modding the truck is to slow down even more.
talkin about rear-ends how can i tell what mine is without pullin the cover off??it is super low though my tach dont work right but bout 70 mph 5th gear it is wide open, the po said it is a ton truck but i dont know if there is such a thing cuz ive squeezed 4 lies already out of him already, i heard someone said they had 4.56 gears could it be?
on
Assuming 5 speed, 4.56 and 235/85/16 tires, I come up with 87 MPH top speed, which is probably too high since you say its running out at 70. I'm guessing your gearing and/or tires are lower.
jac08f250
1999 to 2016 Super Duty
20
08-08-2016 08:56 PM
Moneypit NY
57
11-13-2006 08:19 PM
Lead_Foot
25
08-26-2005 06:00 PM
76 F250 4X4
04-24-2005 12:07 PM
Rayf250
02-24-2005 11:33 AM
