i have a f350 powerstroke 2006 the codes read crank shaft sensor open cam shaft sensor open i replaced both then it showed all the injectors low votage and still shows crank shaft and cam shaft sensor open took it to ford and had it updated then it stopped running when it was running it was blowing black smoke when it would warm up it ran great hi oil pressure 2500 while cranking with the key on fuel pressure 55 im lost any one with any ideas
