Surging Cruise Control
Old Jan 25, 2003 | 02:05 PM
lcommar's Avatar
lcommar
Question Surging Cruise Control
I have an '89 F250 that I love, but it has a problem. When I set the cruise, the truck will speed up by about 5 MPH. Then, the cruise will back off and the truck will slow down by 5-8 MPH. The cruise then kicks in again and speeds the truck up by 5-8 MPH. It never does settle down. It just keeps cycling faster and slower like this. Where's a good place to start? Thanks.
Old Jan 25, 2003 | 02:35 PM
StrangeRanger's Avatar
StrangeRanger
What mods have you done to the engine? It's not unusual for modded engines to hunt (although usually not that badly) in cruise since the computer still adds throttle for a stock engine.
Old Jan 25, 2003 | 04:21 PM
steve83's Avatar
steve83
That old vacuum-type servo is flaky even when new. It has 2 vacuum solenoid valves in it that can get blocked by debris or just sticky with age, and the TPS built into it isn't very good. You CAN take it all apart and clean it up, but you should start looking for a replacement. Either get a newer one from a junkyard (you can get them from Tauruses or anything and swap your cable onto it), or swap to the newer electronic servo like I did.
