affordable injector cup tools from Jim @ rosewood
i was poking around the OBS forums and found this offer thought id pass it along
https://www.ford-trucks.com/forums/9...cup-tools.html
If you don't want to buy one you can put a deposit down and use ours...
It also uses a new system that doesn't require using a tap so you don't get any shavings
Riffraff Diesel: Motorcraft Injector Cup
are they interchangeable?
what is the difference?
by myself
Sorry about the hijack Jim.
Yes, I can supply the sealant and will get an option on the site for you. I have used them and they work awesome.
OK Jim. Thanks. Here's another hijack with a learning experience, especially for early 99 owners.
Chase,
I think you will find this serious enough for another hijack even though you no longer own an early 99.
I just pulled up the UOA results for the oil sample I sent Blackstone last week. There is a trace of oil in the coolant. I read that the organic acid technology ELC was not a good mix with the early 99 injector cup sealant AFTER I did the switch. I should have switched back after reading that but didn't. How .
I was going to get new injectors anyway so I just called Clay and ordered new cups, sealant and the tools along with new injectors and COMP 310 valve springs.
I won't be sure if the ELC is the cause of the coolant in the oil until I pull the cups but that is the most likely cause. I will post when I get the cups out.
I needed something to do anyway because "Idle hands are the devil's workshop"
Chase,
on
Chase,
Chase,
you do mean 910's dont you? mine are going in this weekend as well as the swamps rod's..
I believe the use of ELC in the early 99s was written by Gooch who is quite the expert on coolant. If StewartH reads this post he will have a link if I don't find it first.
I just started a separate thread about potassium and sodium in the oil sample. That's why Blackstone believes there is coolant in the oil.
