Skid plates
Old 04-21-2012, 07:56 PM
HUBBSTER's Avatar
HUBBSTER
HUBBSTER is offline
Skid plates
What kind of skid plates do we have ?
Where can we get better ones ?
Do we have to get them custom made ?
Thanks
Old 04-21-2012, 08:27 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
None, unless you have the optional transfer case skidplate. I haven't seen anything aftermarket. Aside from the tcase, nothing else hangs down. I haven't seen any excursion specific skid plates but if you just want one for the front, the ex is the same as the pickups from the B pillar forward... only the front suspension is lower. If you need a skidplate I'm guessing you are already lifted anyway.
Old 04-21-2012, 10:54 PM
ddivinia's Avatar
ddivinia
ddivinia is offline
That is a good point - I never noticed if I have any skid plates. I don't believe my X has any.
D.
Old 04-22-2012, 06:56 AM
Dubbs19s's Avatar
Dubbs19s
Dubbs19s is offline
I took the Tcase skidplate off my F350 and put it on the excursion. It bolted right up
Old 04-22-2012, 10:11 AM
hasteranger
it was an option on the excursion. Mine has it. You can tell right away if one has it by looking from the side, it hangs down a bit. Its great for going forward, I suppose, but packs mud around your T case if you decide to go backwards.
Old 04-22-2012, 10:12 AM
bjm206's Avatar
bjm206
bjm206 is offline
As others have said you can easily bolt up the factory Ford t-case skid plate.
The space ahead of the front axle is vulnerable to larger sticks, stones etc. that get kicked up while out on the trail. There are a number of companies that make protection for this area. Some of them only list fitment for the pickups. This may be due to the blocker beam. I used one from Asfir that is well made. I needed to modify it slightly to work with my ARB bumper.
For protection from larger sticks, stones etc in the oil pan, transmission and T-case area there are no bolt on options that I know of beyond the factory T-case skid plate. Warn make a skid plate in this area for 2008-2010 pickups (PN 76590). I bought one to use as a starting point for a skid plate and found out that if i notched it for roll bar clearance it bolted right up.
One other area of vulnerability is the rocker panels. It is very easy to drag or bang them. I do not know of anybody that makes bolt-on protectors. I used some aftermarket step tubes and 3" square tube as a starting point. You can see them in the images.
Old 04-22-2012, 10:07 PM
ddivinia's Avatar
ddivinia
ddivinia is offline
Good stuff - might need to hit a wrecking yard for some skid plates to work with.
D.
Old 04-22-2012, 10:08 PM
ddivinia's Avatar
ddivinia
ddivinia is offline
Looking at the astir site:
http://asfir.com/catalogueEN.asp?combo0=23&combo1=100
Which one did you buy?
They list a transfer case one also.
D.
Old 04-23-2012, 10:56 AM
UrbanXX's Avatar
UrbanXX
UrbanXX is offline
I would love to have a factory skid plate for my 2003 Excursion.
Old 04-23-2012, 01:34 PM
bjm206's Avatar
bjm206
bjm206 is offline
The front skid plate is an Asfir 599075 which is listed as a "Steering rod skid plate" for the 04 through 05 F350s. Again it worked really well on my modified 05 Excursion but I would call them to verify fitment as the 04, 05 F350 specification limitation never quite made sense to me. Asfir is an Israeli company so their fitments may have been originally written for export market trucks.
I have never seen their T case skid plate but I would not hesitate in buying one given the quality of the other one I have. The Warn belly skid plate is also well made but again will need modifications to fit an Excursion.
Old 04-23-2012, 01:35 PM
hasteranger
bjm- those are nice looking skids, especially the warn one. If I went off road more I'd try to get something like that.
Old 04-23-2012, 06:43 PM
EXv10's Avatar
EXv10
EXv10 is offline
D.
Lot's o' luck there.
Old 04-23-2012, 08:01 PM
hasteranger
The only people that put skid plates on are serious enthusiasts or specialty applications like drilling or logging companies.... I wouldn't count on either of those companies scrapping any trucks with that kind of equipment still on it. Both groups are likely to pull aftermarket stuff, either for use on other trucks in the fleet or for resale on forums like this one.
Old 04-23-2012, 08:29 PM
ddivinia's Avatar
ddivinia
ddivinia is offline
We got lots of trucks down here in Texas. Finding a factory skid plate should not be too hard.
D.
Old 04-23-2012, 09:24 PM
hasteranger
A factory one should not be too hard to find... hardest thing about finding one in texas will be finding 4wd's.
Quick Reply: Skid plates
