roller cam into a Pinto motor
Old 04-16-2010, 10:44 AM
xfordman's Avatar
xfordman
xfordman is offline
I have a '79 Pinto 2.3 engine. I want to install a roller cam from a '91 Mustang. It will use the stock Pinto Duraspark dist. Will I need to change the dist gear to be compatible with the roller cam? Are there any other issues I need to be aware of?...thanks
Old 04-17-2010, 10:26 AM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
The cam is in the top, the distributor is run off the intermediate shaft, so it won't be affected.
Old 04-18-2010, 07:50 AM
xfordman's Avatar
xfordman
xfordman is offline
OMG...your right, what was I thinking. I guess I was thinking about the 5.0 that I just put in my '53 F100....Thanks
Old 04-27-2010, 12:41 PM
jimbbski's Avatar
jimbbski
jimbbski is offline
I suggest that you change the cam & rockers as a set. The roller cams are steel and the older slider cams are cast iron. Best to use the roller cam with the roller rockers, plus the timing on the roller cams is a bit better. It's been proven that the cam that came on the later Ranger 2.3L is a better street engine cam then on the earlier 2.3Ls non-roller cam engines in the Mustangs.
Old 04-29-2010, 06:54 AM
tomw's Avatar
tomw
tomw is offline
I believe the valve stems on the rollers is a smaller diameter. That almost forces you to change the head to use the roller cam. I saw cam and set of followers on craigslist and considered doing the changeover until I found out about the valve stem difference.
tom
Old 04-30-2010, 06:36 PM
jimbbski's Avatar
jimbbski
jimbbski is offline
I had a 1987 Turbo 2.3L engine that I installed into a 1976 Capri that had a OEM 2.3L carb engine. As part of that install I pulled a cam and roller followers from a 90's Ranger 2.3L. I installed it and had no issues with it. I have never hear that the valve stems are different sizes. This swap was done all of the time by owners of 2.3L Turbo Ford Mustang & T-Birds when the roller cam and roller rockers were introduced in the 90's. The last Turbo engine was made in 1989 and sold in the Mekur.
Old 05-01-2010, 07:43 AM
tomw's Avatar
tomw
tomw is offline
Well, that depends, jimbbski:
Quote:
"Heads-
All 2.0/2.3/2.5 heads will physically bolt in place of each other, they all have similar
exhaust port shape and placement. All cams are interchangeable as long as they
are used with the proper followers. Later model ('95 and newer) roller cam
followers cannot be easily swapped onto an older head as the valve stem size was
reduced in the newer heads and matching slot in the follower was reduced.
Early 2.0 and 2.3 heads have the same small round intake ports spaced evenly apart, they differ from each other in their valve sizes though "
"There are several variations on the 2.3 heads though they break down into 4 distinct types:
1. Passenger car oval port heads-’74-’80 Mustang, Pinto, Fairmont, Bobcat, etc.
2. Passenger car D-port head-’81-’95? T-bird, Mustang, Etc.
3. Truck round port- ’83-’85 Ranger
4. Truck D-port- ’89-’01 Ranger. The '89-'94's and '95-'01's have different combustion chambers and ports. "
stolen from "therangerstation.com"
The valve stem diameter is different in the later models. Do you need part #'s?
tom
Old 10-19-2010, 07:57 PM
jfive's Avatar
jfive
jfive is offline
89 to 94 valve stems are the same, 95 to 01 are smaller. Need the followers(roller rockers) from a 89 to 94 in rangers or 91 to 93 mustang.
jtapal
02-08-2017 03:55 PM
Shaggie
4 Cylinder Engines
09-14-2015 10:29 PM
400inatruck
01-29-2013 05:57 PM
my93
Engine Swaps
01-19-2011 08:26 AM
Show-N-Go LX
32
11-29-2005 10:59 AM
Quick Reply: roller cam into a Pinto motor
