hi/wiring ?
hi/wiring ?
i am new to this site and new to owning a 76 ford crew cab.
i live in salem, and i am looking for somebody to fix the wiring mess in my truck. i dont have the time or skill to do this my self so i am looking for a good shop or maybe a privite preson who is good at wiring to help me with this. any info with be a great help to me.
thanks
trainwrecker.
thanks
trainwrecker.
i am having lighting trouble mostly. out of all the fueses in the box under the dash only 2 have power to them and the only thing that does not work is the break light. so i just cant figure out how everything else is working. and it seems to be mostly stock wiring and not all hacked up.
As for the brake lights check the fuse as previously stated, take some light sand paper and clean the fuse contacts while your at it. On these older trucks the tail light grounds come off the body so it is very important that the engine to body ground strap is clean and connected properly.
"the only thing that don't work is the brake lights"
Brake light switch is on the brake peddle under the dash. Prone to failure........ Should have power to one side if the fuse and wiring is ok. If there is power at the switch and the switch itself works the problem is most likely in the turn signal switch. Another common problem.
laxdad
09-18-2015 11:50 AM
Mister_King
Electrical Systems/Wiring
03-06-2015 06:45 AM
charon61285
10-22-2004 08:27 AM
Oscar Meier
12-23-2003 10:06 PM
