Cranks forever
Old Mar 22, 2010 | 03:08 PM
Stroked99's Avatar
Stroked99
Cranks forever
My wifes Expedition is an 03'. I ran the AE on it and discovered a misfire on the #1 coil (which I have since changed). The biggest issue that I have is that it takes forever for the truck to fire up in the morning or after sitting a while. Literally you have to crank it for a good 20 to 30 seconds before it starts. Way to long in my books. I have checked and replaced the elbow behind intake. The only other thing I can think it to be would be low fuel pressure, which would elude me to a bad fuel pump. Any suggestions.
Andy
Old Mar 22, 2010 | 04:52 PM
alloro's Avatar
alloro
Others that have reported these same symptoms ended up replacing their fuel pump to fix the problem.
Old Mar 22, 2010 | 06:20 PM
Stroked99's Avatar
Stroked99
And I am sure it is one of those in the tank job, right.....
Old Mar 22, 2010 | 07:02 PM
alloro's Avatar
alloro
You guessed it, so don't just assume it's bad, do a fuel pressure test on it.
Old Mar 22, 2010 | 07:06 PM
Stroked99's Avatar
Stroked99
I will have to take a look a my manual, but what kind of pressure are we looking for?
Old Mar 22, 2010 | 11:19 PM
khangmai's Avatar
khangmai
https://www.ford-trucks.com/forums/3...tarting-2.html
check out that link, good info there.
