SCT Live Wire
Just my opinion but you run just as much risk of voiding warranty when you run a tuner with the DPF on as you do with it off. The only thing you save is the time it takes to switch it out. So if you are truly worried about warranty then you might want to forget the tuner. The "tuner in a can" versions such as the SCT still flash the PCM and can be traced, they are actually supposed to be much easier to trace than the Banks or Spartan setups. Just want to make sure you are well informed before you throw your warranty out the window. Good Luck.
9228.bobcat
Ford Truck Parts for Sale
05-08-2014 06:25 PM
