View Poll Results: exhaust options
1. cat back only
100.00%
2. cut out cat
0%
3. true dual exhaust keep two O2 sensors
0%
Voters: 3. You may not vote on this poll
1996 Full size bronco exhaust options/opinions
I am rebuiling my Bronco.
I am getting a long block 351w efi engine and I ordered a set of JBA shorty stainless steel headers.
The question is.....
1. Use a only a cat back system - Flowmaster 40 series muffler - single in / dual out.
2. Cut out cat and use same system as above.
3. Go true dual exhaust - keep two existing O2 sensors, no cat, two mufflers, etc.
#3 won't work; you're ODBII
What I would do is get a Bassani y pipe.
1995 Ford Bronco Bassani Y Pipe
Or make your own like I'm going to do. Being a 96 you're ODBII you should have an extra O2 sensor behind the cat. Bassani doesn't list a y pipe for the 96, but you could probably just add an extra bung after the cat and be good.
I'm going to cut up an old mustang H pipe I have and use some mandrel bends and a flowmaster 2-1 Y pipe with a 3" outlet into a 3" cat, 3" muffler and 3" maremount mandrel bent tailpipe.
Go to autozone and order the Autozone 577061 / Maremont M30001 tailpipe. It's 3" mandrel bent and costs about $50. You have to cut 12-18" off the front and add hangers, but it fits great. Support the truck and let the rear axle hang and leave 1/4" clearance between the spring and pipe so it's up as high as you can get it. It'll look low, but it's not in the way of anything on or off road. Lots of Bronco guys run this pipe and don't have clearance issues.
What ever you do, make sure you focus on the Y pipe. That's the biggest restriction in the system even with a holed out cat or straight pipe. The bends are horrible. You can even neck it down and go with a stock type muffler if you want quiet and still pick up performance.
Chappelljr
23
11-08-2015 08:43 AM
GI8U2racing
04-29-2010 03:12 PM
