I need an entire brake system
Well, now, let's be careful of this "out of spec" business when it comes to the cast iron brake drums. "Out of spec" is a dealer racket that has been picked up by the aftermarket guys. My '67 old brown sow has 300,000 miles on the original drums which have never been put on a lathe. Every 15k miles she gets front linings and every 30k miles she gets rears. Yeah, the drums are grooved but she has never had metal to metal on her brakes. Yeah, she is a mildly-driven flatlander but I am sure if I bit on this "out of spec" bait, she would be on her fifth set of drums.
Has anyone ever know of a brake drum explosion from an "out of spec" drum?
This one is sure to provoke the old salts.
Semper Fi
Semper Fi
I have seen them break. I have seen them wore so bad your e brake didn't have enough adjustment to work. Any time they are out of spec your wheel cylinders stay extended more than they are made to amplifying the chance of a leak.
I have to ask why do you run grooved drums, it is not like they are expensive, and it is your brakes.
Starmilt is right, of course, but there is some truth in what I posted above about "out of spec".
Drums may be cheap, I don't know, I don't buy them. But rotors sure aren't cheap. A few years ago I took in a set of rotors to be turned. I had done one brake job before and the clown high school kid set the lathe so deep that he destroyed the rotors. They were "out of spec" and could not be cut again. Big aggravation and cost to replace.
I got in my habits decades ago when I was poverty-stricken. Now that I am merely poor, I think I will invest in a set of drums for my '67.
Semper Fi
Semper Fi
Before this thread closes out, I want to share with you folks what Toothless Jake taught me about checking the serviceability of brake drums. There are three tests:
1) The "Stomp" Test- Put the drum on a flat deck, like a driveway, outside up, and stomp it. Not too hard. If it falls in, replace.
2) The "Warp" test- Grab the drum in both hands and twist. If it noticeably distorts, like a pie plate, replace.
3) The "See-Through" test- Shine a penlight flashlight through the drum from the inside, the grooved shiny surface, out. If light comes through anywhere, replace.
You can get free replacement drums in the discard "out of spec" bin behind your local Sears or Midas franchise. Fish around for a replacement and you are assured of another 100,000 miles of reasonably safe service.
I hope this helps.
Semper Fi
I hope this helps.
Semper Fi
Well I've located most of the parts I need from my local Napa dealer for prices less then I expected. New drums at less then $50 each seems reasonable to me. I am still debating adding the booster or not. I need to check the chapters forum and see if any one in my local area want s to get greasy for a few hours to assist with the job. Thanks for all your help and responses. I will post my progress.
Joe
Joe
on
For now I think I am leaning towards installing all brand new parts for a new drum brake system but maybe adding the power booster as well. I live in the small town of Suisun City which is in the greater San Francisco bay area. I still need to track down new drums and other items but am interested in doing the job in the next few weeks if possible.
I'd be willing to help if I can fit it in the schedule.
#28
#29
Let me know it this will fit your schedule.
Joe
#30
Sometimes I hate you guys with the F100's
I needed front drums for my '68 F250 and the local parts store could get them for about $80-$90 each side retail cost. Luckily I found someone to let me use there "shop discount" and got both for $60.
Joco brakes are fairly simple to work on.
The chilton or Hanes books should walk you through the process. And I think any special brake tools can be rented or borrowed from some of the chain auto part stores. If I remember correctly I gave one of the chain stores $50 for a brake bleader and when I returned it they gave me the $50 back.
As for the booster. Im not sure but you might have to replace or at least rebend the master cylinder lines. The booster will move the master cylinder into the engine bay a few inches.
And I have learned a lot from this forum. Some of the guys here even help me out with my non truck problems and even non Ford problems.
