my new Custom 3.5" Single Exhaust
#31
Do you think a Magnaflow 14151 will tone it down a bit more than the Dynomax? MagnaFlow 14151 - MagnaFlow Stainless Steel Race Series Mufflers - Overview - SummitRacing.com
Have you driven it under load? I'm sure that thing barks pretty good.
#32
Thanks FORDF250HXLT for this post and the pictures - I decided to do pretty much the same thing.
Most of my exhaust components arrived yesterday. I'm going 3.5" from the downpipe (3") but I still need to find the right 45* that will take it up the firewall and couple with the DP.
I went with the same muffler but with 4" flanges and purchased a 3.5" to 4" reducer to mate the intermediate pipe up.
The reason why I did this was I noticed you couldn't find a ready made solution for the tail pipe to go over the axle and out.
I couldn't either - at least in a 3.5" - but I found a 4" complete exhaust kit for the 7.3L N/A (Summit # 19340) that includes a ready made tailpipe and discovered they sell the tailpipe as a separate replacement for $62 + $9 extra shipping. (Summit part# 54387) when you see the complete exhaust kits it goes with (19430) the application is for the 88-94 F250. You can see a picture of the tail pipe in the kit.
Sweet!! That's much cheaper then buying a bunch of 90* bends to trying to make a tail pipe (thats what my OEM unit looks like) and I can't find a shop that will bend 3.5" tube. (which would cost even more $$)
It's still on order. I purchased a 4" to 5" polished tip to finish off the look. The 4" pipe will look burly especially with the 5" polished tip.
I'll post a picture when everything arrives.. Hope this will help you out..
#33
on
No i don't.It's pretty much the same style muffler(just costs more)
i would recommend going with a milder muffler for your use.like the Dynomax Turbo muffler.
try this one:
#17789
this ones still a good performance,but will have a little bit more back pressure.but you need to compromise somewhere.it's doubtful the IDI will even know it's there anyway.
notice that part number is one of a few 3" in/out mufflers.But it's also the longest.this extra length will help keep the noise down for your horses.
i can't promise this one would be tame enough for you.but this is the one i would start with.anything beyond this,will likely be to much for hauling horses.
I never had plans to exit out back.was always my plans to exit in front of the tire.so i never tried to find a tail pipe.
due to always bending them up backing into brush piles etc,i always exit in front of the rear pass tire.
if i where to look for one,i would search for 94.5-97 PSD exhausts though.you should be able to find a tail pipe like that easy enough.
i see you found one though,so your all set.
yeah,same results as me then uh.i guess most mandrel benders only go up to 3".
maybe in a big city or something,or a custom diesel muffler shop they buy the larger benders.they probably cost a lot more is why most places don't have them.
your going to love the setup im sure of it.can't wait to hear what you think and pics! get ready for a big deep tone.yeah that's going to look nice with a 5" tip
#34
#36
Just for anyones info, i was told the same thing for a y pipe fabrication and i about shat. After some searching i found a 3 inch two in one out Y from magnaflow. It is about 40-50 bucks. I have gotten really good at making the y's now so i may just start making them as a production!! hahaha.
EDIT autoanything.com has them for 26 bucks. Wow good time for a sale!
#37
Jason,
try this one:
#17789
try this one:
#17789
#38
on
your welcome,and thanks.
iv since tossed that 90 degree elbow.since i removed it,it's actually much quieter in the cab.at first i thought it helped.
i didn't have any luck trying to rig up a 90/45 combo or anything to get me out in front of the tire,so i took those parts back and gained back some $ of course.
im likely going to check around and perhaps travel to a shop who can bend 3.5" pipe and have a nice tail pipe fit.
perhaps i'll just have a 3" pipe fit here,as i wouldn't mind a little less deep tone anyway.she is pretty strong sounding when im hauling (which is often) however,im going to wait until after i install the under body tool box.
yeah,i know the feeling Jason.it's important to try and stick with a game plan.
i can't wait until im closer to being finished.i like working on her enough,but man i'll be happy when the bulk of the transformation is complete lol.
i moved up this mod,due to today's fuel prices.i figured the sooner i did this one,the sooner i could start saving a bit on fuel.
#41
#42
#44
#45
Even if you throw in the welder I am 100 bucks under that cost estimate. And mine is dual 3" to single 4". If I had to pay for that custom stack things would be different. Lol. Again like I say every time, get the mandrel bent pipe and cut/weld it to fit. You do not need to have it bent. For thinwall pipe you only need a wire feed arc welder. If you are patient, the welds look factory but I grind them down for coating anyway. To each their own!
