Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
1st Gen carb swap with E4OD
Old 03-19-2010, 07:14 PM
Birddog1220's Avatar
Birddog1220
Birddog1220 is offline
I'm in need of some help, have a 93 with 260/260 .475 lift cam, Shaved and ported heads, free flowing exhaust.....and speed density EFI. The cheapest and simplest way to go seems a 650 cfm carb and performer rpm intake. But what of the computer controlled trans? If I leave all the wiring in place, will the computer still function properly without the wires being hooked to the injectors and tps sensor? BTW my plugs look like this computer screen.....White. Any help here is greatly appreciated.
Old 03-25-2010, 10:07 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
You'll need to run a stand alone transmission controller like the Baumanator, if you plan to use your E4OD with a carb
Old 05-01-2010, 12:06 AM
DDD's Avatar
DDD
DDD is offline
like this?
and yes everything works! cruise,a/c and yes it is a daily driver
Old 05-02-2010, 07:22 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I'm not sure why you would want to do that. The carb setup is really a downgrade, not an upgrade. What about MAF conversion? Many guys with speed density Lightnings that are modded work fine with the speed density.
Birddog1220
20
08-10-2023 09:40 AM
mary-kate
37
03-09-2018 11:00 AM
goodtyms1432
2015 - 2020 F150
04-11-2017 04:39 PM
Bib
03-19-2017 07:11 AM
jas88
08-14-2003 08:55 AM
Quick Reply: 1st Gen carb swap with E4OD
