94' F250 Turn signal, brake lights don't work
I have a 94 F-250. The Turn signals, bake lights and hazzards quite working. THe indicator lights in the dash don't work either.
From doing some looking around I see it may be the turn signal switch. Where is this switch at?
Is there a way to test the switch to see if that is really the problem?
Thanks,
Thanks,
Its probably going to be the turn signal switch itself, called a "Multi function switch".
Everything you have issue with goes through it, yea even the brake lights.
And yea you can test it if you want to verify it is the switch. Remove the switch and unplug it, then jumper across the pins with a wire to run the various lights to verify it as the fault.
dwcford
26
07-18-2017 10:38 PM
Krisverde
08-06-2013 11:06 AM
tcoates
03-09-2009 03:41 PM
