Corner Lights wont Blink on a 94 F150
I'm trying to track down the culprit that is keeping my front corner lights from blinking. I think that its something simple so I thought I'd ask.. Here's the facts:
When I turn on the left or right signal, the lights on that side blink fast as if a bulb has blown.
You can barely feel or hear the click coming from the relay.
The relay sounds normal with the hazards on but still no blinking from the corner lights.
Bulbs are good.
Relay is good (does the same thing with a new one)
I'm pretty sure the turn signal switch had been replaced within the past few years.
Fuse is good (only one that I know of that would be the reason. #7 iaw OM.
I've only had the truck for a month so I'm kinda guessing that maybe somebody screwed something up when installing the new switch but everything else works and it also strays from something simple theory. Any suggestions?
Bulbs are good.
aortizexcursion
02-20-2014 01:04 PM
Fastfwd
1999 to 2016 Super Duty
08-22-2013 10:02 AM
dwildey
04-19-2010 06:19 AM
