engine swap
on
1 Post
If you can figure out how to mount the tank where the spare tire carrier is - between the frame rails behind the rear axle - and move the fuel tank door. That's about the only way I know to use a Bronco II fuel tank in a Ranger. Did you read the page I linked above regarding the Duraspark conversion? Here it is again:
The Ford Ranger/Bronco II 2.8L Duraspark Ignition Conversion
I believe the connectors you need are still present on the 2nd gen Rangers. I know for sure that they are installed on my '87 Bronco II. You can also Google "Duraspark Conversion Ford Ranger Bronco II" and probably pull several links to write-ups and discussions on it.
The Phenom
1983 - 2012 Ranger & B-Series
02-26-2005 12:22 PM
