88 L8000 info needed
I recently acquired a 88 L8000.
Power/ diesel 6 cylinder. I know one thing for sure. its not Cat/Detroit/Cummins/IH. Has Ford Logos on it and is rated at 210 hp. One guy told me its related to the ford tractor engine. Any body know anything else about them?
Transmission is an Allison automatic.
And I need a wiring diagram. The original cab, Which I got in the deal was rotted out bad. The swapped out the cabs. Tach and speedometer don't work. All fuses are good. But there are wires on the firewall junction strips that are not hooked up.
I'll post pics later. Got it for $3000, 124,000 original miles. It was an old Pepsi truck. Was used for a yard truck to move trailers and plow snow.
Thanks jpr. Since you say bored and sleeved I'm assuming these are not a sleeved engine then.
I think my electrical problem is ground. tach started working when I moved it out of the shop today. Gauges wack out once in a while and the where working for a while today. I'll chase that gremlin first of the week.
Got the interior part way back in today. Sure is nice to sit on a seat instead of a 5 gallon bucket
For all you know, the cab is grounding through the steering column
Correct, they are not sleeved engines. And go with Krewat's suggestion for the gauge issue about looking for a ground issue.
1985L8000cat3208
Large Truck
03-02-2012 11:48 PM
