03 Aviator Problems ABS and Cruise
We are traveling today, and for the rest of the week, yesterday when we were driving the Aviator, everything was working, today my wife is driving, and first thing that she noticed was the cruise would not turn on and set. about 40 miles down the road the (ABS) light came on.
I am sure that there is already a thread about this, but I am on really slow cellular internet right now, and search isn't working for me. Any advice about the problems I am having would be appreciated (other than switching internet services LOL?)
Where do I start looking, if I get a chance? or is it best that I just take it to a mechanic?
The vehicle speed signal for the cruise control is sourced by the ABS system. If you have a faulty wheel speed sensor that might cause explain the ABS light as well as the cruise not working. A scan tool capable of reading the ABS codes will likely tell you where the problem is which will fix both issues. From my quick review of the wiring diagrams I'm not sure if the speedometer is also sourced from the ABS system.
-Rod
-Rod
Or spend the same $$$ you would on diagnostic and purchase a scanner that is capable of running the full scan (including the extended mfg codes), you will then have it handy for future testing...
http://www.obdscan.net/index.htm
http://www.bowserelectronics.com/pro..._options.shtml
http://www.autoenginuity.com/order.html
Note: I have no affiliation with these products, just list as examples, there are many other just as capable....
That's neat that the first two links cover the ABS and SRS systems. I don't see where the AutoEnginuity has the capability. On other forums the discussion has come up regarding PC-based diagnostic tools that also can read ABS and SRS. To date I hadn't seen any discussions that confirmed a tool supported those. Next time I'll have some input for those threads.... For now I'll stick with my OTC Genisys though.
-Rod
-Rod
-Rod
-Rod
Fact, on several other PC programs I am not able to access data on my O2's (some state no O2 available!! but with the Harrison's "Ford extended" (via PID) I can get all the info I require.
My '04 Explorer XLT is doing the exact same thing. I has done it sporadically in the past 2 years, now it is doing it more frequently. If I can successfully read the codes, where are these wheel speed sensors at and how hard are they to change? And I assume the switch on the master cylinder is fairly easy to change?
Millinex
05-10-2017 04:08 PM
ReluctantMechanic
04-26-2016 09:27 PM
hansbro89
02-12-2016 12:17 PM
Andyriv
03-03-2010 11:44 AM
