Oil Pressure light?? off and on?
Drove 30 minutes home from a doctor's appt in my 1999 F250 witht the 5.4L and pulled into the driveway to let my dad get the mail, looked down at the dash and the oil pressure light comes on and the gauge dropped, turned all the accessories off and could hear the rollers ticking and rattling from no oil, pulled up to the house shut it off, let it cool for a couple minutes, turned it back on and the same thing happened, shut it off and changed the oil, it rattled for a minute and then quit, and oil pressure was back, light went off, later on it flickered but then returned to normal
any ideas to what may have caused this? I can't figure it out
you sure you actualy had no oil presure ? might be a sign the pressure sending unit is failing or getting ready to fail...
i had a 2000 F150 with a 5.4 that had that exact scenario happen. turned out to be a cheap repair getting the sending unit replaced.
i did have horrible visions of a bad oil pump.. luckily it wasnt...
You didn't say how many miles were on your engine, but unless you correct the cause of the oil pressure dropping you'll be replacing it very soon.
Sounds like the entire engine needs to be torn down and rebuilt.
If the motor was rapping, thats a pretty sure way of telling you either you had little oil or little to no pressure. Did you note how much oil you removed from the engine?
Could be clogged pick-up or the pumps on its way out but they typically aren't intermittent. Also assuming you replaced the filter as well.
