limited slip
Old Mar 13, 2010 | 05:08 PM
1bad67sbf's Avatar
1bad67sbf
limited slip
my truck has an open diff do the xlt crew have lockers for low range and if so can it be used out of low range? if not what brands are reliable limited slip (was thinking detroit tru trac)
Old Mar 13, 2010 | 09:41 PM
Ryan50hrl's Avatar
Ryan50hrl
the xlt did not come with a locker.....the fx4 had an avialable locker however it was lo range only....tru trac is a good ls and i've used eaton posi's before with very good results....
Old Mar 14, 2010 | 12:53 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
none of the 04-08's have a locker
the best you can get OEM is the Limited slip...which is available in all models. standard on FX4 though.
I actually like the factory tru-trac. never had one fail me in my Mustangs various F-150's. but if you want a true locker...go with the detroit
Old Mar 14, 2010 | 08:12 AM
1bad67sbf's Avatar
1bad67sbf
thanks do you have a ball park price (or hour amount) it cost to have installed, i thought mine may have some kind of ls or locker because when in 4 wheel drive if i pull onto a patch of black top it will cherp the tires when i turn untill i take out of 4 wheel
Old Mar 14, 2010 | 08:17 AM
shotgunz's Avatar
shotgunz
Do not use 4WD on pavement unless you want to pay for the locker AND a new front differential.
Old Mar 14, 2010 | 08:23 AM
1bad67sbf's Avatar
1bad67sbf
yeah i know (i dont like the cherp sound) but in snow or mud if i take it out before i get on black top i just burn rear tires i live in no va and we got a stupid amount of snow this year (most ever recorded)
Old Mar 14, 2010 | 10:36 AM
HYPO's Avatar
HYPO
I paid $549.00 for the True trac on e-bay, $175.00 for the install. That was in November '08. I live in SE Michigan (Detroit area).
HYPO
Old Mar 14, 2010 | 10:49 AM
1bad67sbf's Avatar
1bad67sbf
do you think it was worth it or not (would you do it again?)
Old Mar 14, 2010 | 11:14 AM
HYPO's Avatar
HYPO
Do I think it was worth it? I not only think it was worth it, I'm thinking about putting one in the front diff too!
HYPO
Old Mar 14, 2010 | 11:21 AM
1bad67sbf's Avatar
1bad67sbf
thats what i figured i cant wait to get mine but i just dropped $1300 on wheels and tires so it has to wait for now (and if i get a tru-trac in the rear it wont be long before i need tires again)
Jon351m
Jan 20, 2013 02:14 PM
Sparky04SD
Mar 16, 2011 12:14 AM
Frdtrtnv8
2004 - 2008 F150
22
Dec 23, 2008 06:23 PM
obx31
Aug 4, 2003 01:48 PM
