COP wire connector problem.
hey guys i was changing a Coil on my 97 F-150 5.4 and i accidentally pulled the 2 wires out of the connector and i cannot get them to go back into place. i can get them into the connector but they will not lock. is there a trick to it? i know on alot of wire connectors you can take a pick and depress the tabs to remove or install the wires from it. but these dont appear to be that way. any help is appreciated!
holdendaniels
03-20-2016 06:04 PM
54, coil, connection, connector, connectors, cop, copwire, disconnect, f150, f350, ford, plug, remove, v8, wire
