Rear Axle Vent Piece
Thanks- so all I need is a length of rubber hose clamped to the nipple and then run it up somewhere else along the frame. Where do I get nice new hose to frame clips like you have there?
Also- why does the longer tube keep oil from spraying out? Does the air pressure just push the oil out the longer tube?
Don't know where you can get those pretty clips.... parts store 'help' section? Zip tie?
Anyway, the longer tube will help keep the "oily mist" from spewing out like a short one would. You shouldn't have an oil "leak." It's a breather...just there to keep the inside/outside air pressure equalized so the seals don't blow out....as long as its not plugged up.
FractureCritical
1999 to 2016 Super Duty
11-04-2017 11:08 AM
66with352
12-09-2016 05:43 AM
rogerranger2122
1983 - 2012 Ranger & B-Series
10-03-2016 09:22 PM
pcurtice
09-21-2016 08:04 PM
DirtyDieselPhil
12-20-2004 03:50 PM
