'97 F-150 2wd pickup rear driveshaft problems
After failing to get the U joint cups out with with larger and larger C clamps, I decided to remove the shaft and press them out. In removing the rear pinion flange bolts, I'm concerned that one or more might twist off, what diameter and pitch are they? Appears to be metric, 10MM?
