2004 F150 5.4 Lariat-Aux jack
No
2004-2006 Ford did not have a built in jack...there is a input capability
if you want to add a headphone jack (for iPod or similar), you have three choices
1. Pie Adapter - run about $100. They integrate with your factory harness and allows you to add a input using the Aux button. The Aux button is typically reserved for a cd changer...so it works pretty well actually
2. New aftermarket radio - self explanetory
3. Install a 2007-2008 radio from a Mustang/F150/Expy/And lots of other Fords. These radios have 3 wiring harnesses. 1 of them is a 4 wire harness that is exclusively for a 3.5mm input jack.
I recently put a Jvc Dvd unit into my Expy. Pretty easy to get into there and look around. Tons of room in the dash.
Alot of guys have bought a female input jack from Radio Shack and just custom wired it in. Which is essentially what the Pie Adapter does without any of the guesswork
No
I you are interested in making that auxiliary button do something check out this post:
https://www.ford-trucks.com/forums/9...iary-port.html
Hey did you have any issue using your cds afterwards? I've got a 6 CD changer and was told that the adapter would disconnect the use of cds in order to play music through my auxiliary. Let me know thanks.
nicechad2
16
12-03-2018 12:49 PM
notmyrealname
05-06-2017 04:18 PM
spinner605
03-02-2017 12:38 PM
