Time for new tires on the dually- UUUGGHHH, got any advice?
The current Dumlop Radial Rover's I have on are about done, with only 28k on them. Luckily, I can get a warantee on 4 of them through the local tire guy I always go to. He knows me and gives me a break 'cause I'm in the service. I paid $900 out the door for the last set of 6 w all the usual service, so I like to go back to him.
Anyways, I was thinking of this time getting something that will last a good long time. Since I don't have a lift I figured I'd stick with the stoc size 235's, which will also keep my fuel consumption lower than lets say a 255 size tire. I was considering getting 2 Michelin XPS rib tires on the front, and then 4 Michelins on the back with some tread to them for mild off road gripping power.
Anyne ever done that? I know alot of OTR truckers do, and it looks a little goofy, but there's a purpose for it I guess. Or do y'all have any recommendations for a long last AT tire? The set before these I had BFG KO/AT or something like that, and they again only lasted about 35-40k. Thanks for any advice!
I love my Michelins 's LTX's.. on my dually.. I have almost 30K on them now and show very little wear..and wearing even.. unlike my original Generals which cupped and had uneven wear.. One thing I have noticed about Michelin tires.. never had a flat with them.. Maybe I am just lucky..
you better knock on wood
I know I'm gonna jinx myself, but since I bought the truck in july of 06, the only flat I had was on the left outside tire when a 9/16ths wrench punched through the corner of the tire! Some dummy lost a tool, and I found it for him.... Also never had to replace a headlight yet either (Kncoking on wood)
I think I might just swing for the Michelins. Expensive, but I know they will last. Hey Rick, did you have to put a spacer in between the rears, and how did that bigger tire effct your mileage?
Of course I'll get E tires- so I'm guessing you got yours used right? 'Cause I know stock they come with those cute little 235's. I asked about the spacer because I thought I read somewhere that they can run with enough weight in the bed (like a trailer) I don't want to have to soend a few hundred just for a spacer. If I had to I could probably get the machine shop on the airstaiton to make some 1/2" spacers outta "aircraft structural" steel
The best milage I got on steering tires were the oigional firestones had lots of tread left a 53k when they separated.On the drive was uniroyals with over 80k
At 136k I'm on my second set on drives and third set on steering tires.If I keep the truck this should be my last set
This set is firestones again
