Power Steering addition..Any help would be appreciated..
Old 08-04-2010, 02:49 PM
4GET4N's Avatar
4GET4N
4GET4N is offline
I have a 1965 Fleetside short bed with a 352 motor, non power steering..
would this power steering unit work on my truck?
Ford F-100 Power Steering Pump/Bracket & Hoses
Thanks!
Old 08-04-2010, 07:34 PM
garbz2's Avatar
garbz2
garbz2 is offline
No, it is for a small block application. You need donor brackets and pump/box from a FE equipped truck. Avoid the bendx as it is junk. Steering column modifications are needed on your stock unit.
Garbz
Old 08-04-2010, 09:16 PM
OldHarley's Avatar
OldHarley
OldHarley is offline
Thanks!
That ain't a power steering unit, bub!! It is only a power steering pump with the pulleys and mounting brackets. You still need a box!
...and as Garbz2 says, it's not the right one for a 352!
...you know, I'm beginning to sound like jowilker I need a vacation.
Reason for edit: Added the word 'bub' so it WOULD sound like jowilker
donniehark
12-13-2011 02:21 PM
61ford4u
05-30-2008 07:30 PM
kmusmc
15
04-29-2005 08:45 AM
jessecoit
12-19-2003 06:49 AM
Quick Reply: Power Steering addition..Any help would be appreciated..
