Need help. Autoenginuity in KC area?
Old 03-09-2010, 09:31 PM
cutlass's Avatar
cutlass
cutlass is offline
I have been chasing an engine miss/chug/shudder for far too long now and it's getting to the point where the engine is running horribly and I am out of patience in trying to come up with a solution.
Is there anyone here on FTE who lives in the Kansas City area who has Autoenginuity that I could hook my truck up to and diagnose my sick truck?
Thanks.
Old 03-09-2010, 11:36 PM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
Here is a bump for you.
Old 03-10-2010, 09:49 AM
Justin03PSD's Avatar
Justin03PSD
Justin03PSD is offline
Thanks.
I would be glad to help. Shoot me a PM and we can figure something out.
Old 03-10-2010, 10:16 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
I think Justin will get you fixed up. Check the UVCH while waiting. Reps to you Justin.
Old 03-10-2010, 10:46 AM
cutlass's Avatar
cutlass
cutlass is offline
Justin
Thanks, that's great! Only problem I have is I'm a new member here and am unable to PM. Maybe I can but just don't know how to.
-Drake
Old 03-10-2010, 10:49 AM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Drake,
Would you like me to PM Justin your phone number?
Justin03PSD
Justin
-Drake
Better get to postin', son!
edit: got your number, will call soon
Old 03-10-2010, 10:51 AM
cutlass's Avatar
cutlass
cutlass is offline
Originally Posted by PaysonPSD
Drake,
Robin,
Sure, pass on my cell phone # to Justin.
Thanks,
Drake
Old 03-10-2010, 10:55 AM
PaysonPSD's Avatar
PaysonPSD
PM sent to Justin.
Old 03-10-2010, 10:57 AM
PaysonPSD's Avatar
PaysonPSD
Great offer of help. You are a true FTE Brother. Reps sent.
Old 03-10-2010, 11:13 AM
Justin03PSD
Thanks for the number Payson! And nice speaking to you Drake.
If you all can suggest anything specific to test, please speak up. I've only done a bit of logging on my truck, so am far from an expert. I was thinking to try the buzz and contribution tests.
Old 03-10-2010, 12:03 PM
PaysonPSD's Avatar
PaysonPSD
You probably already thought of this, but might as well look at ICP and IPR Duty Cycle while you're at it. And do some logging while it is acting up.
Remember, the buzz test is only an electrical test of the solenoids. If the CCT points at a particular cylinder you really need to pull the valve cover and check injector oil discharge. Also with the new grey CPS #3 & #8 tend to fail CCT.
Old 03-10-2010, 10:26 PM
cutlass's Avatar
cutlass
cutlass is offline
I have the new international CPS that's dark blue with a purple o-ring. Are there any issues that anyone knows of that applies to this one?
Also, is there something regarding rotational velocity that should be checked when concerned with possible problem injectors?
Drake
Old 03-10-2010, 11:00 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Drake
Yes, the rotational velocity (PERDEL) readings can help you narrow in on some issues. However, like PaysonPSD said...I wouldn't hold too much faith in the readings on #3 or #8. The engine oil temp has to be around 140 before the readings will show and they won't show at all if you have any IDM codes present (1316 with SES light). So, eventually you are going to end up starting the engine with the valve covers off and looking at the oil discharge anyway, so you may not want to wait until the engine oil heats up. So skip the rotational velocities for now...
You probably already know this but I'll mention it anyway Be advised that the buzz tests fires all the solenoids all the time. What happens is it fires all the solenoids at once, then it fires them all 8 more times. It will start with cylinder #1 at full strength while the other 7 cylinders get a soft signal, then it moves onto #2 and so on. So, a soft sounding solenoid may not be getting any power at all, even though you think you hear it buzzing slightly.
It took me a while to figure this out myself so I thought I'd save you the trouble in case you didn't already know this.
Old 03-11-2010, 10:01 AM
cutlass's Avatar
cutlass
cutlass is offline
Thanks for the info gchavez. Does anyone have any other suggestions or has everything already been covered?
-Drake
Quick Reply: Need help. Autoenginuity in KC area?
