Skull thumper.
Old Mar 9, 2010 | 08:17 PM
flipklos's Avatar
flipklos
Skull thumper.
Some of you may recall I chased an ignition ghost a few months back and resolved it somewhat by tweeking my timing and changing wires. The sun of a gun is back! The same day I changed my wires i also tightened all my lifters down 1/4 turn in case I had an issue there.
I am seriously woundering if I have a lobe that has been smoked on my cam. I aim to do a compression test here soon and am currious as to what you guys are getting for a stock CR on a carbed 300. My guess would be about 100-120 psi hot.
Also, is a dialindicator opperating off the pushrod an acceptable means of field testing the lobe lift on a camshaft?
Thanks yall.
Old Mar 9, 2010 | 09:48 PM
4x4 Bart's Avatar
4x4 Bart
Dial indicator on pushrod will check to lift quickly.
Old Mar 9, 2010 | 11:58 PM
freednighthawk's Avatar
freednighthawk
As long as you have it mounted securely. One of my classmates (not the sharpest tool in the shed) tried holding the dial indicator by hand while having someone turn the engine over via breaker bar on the harmonic balancer on a GM 2.5 in a Heep... Err, Jeep.
Old Mar 13, 2010 | 02:24 PM
flipklos's Avatar
flipklos
I didint bother checking the lift. But I set the vales today. I did what my uncle said he used to do with the 300s he had in the fleet.
I simply took them all loose and checked the pushrods for straightness. Then I brought them to a zero lash at TDC. I started the engine and in 1/4 turn increments brought all the jam nuts down to the end of the threads. My hopping vaccum is gone! It used to hop about a full inch and I could never set the initial spark timing without causing a slight miss. I got rid of the vaccum hop, twisted the distributor ever so slightly and pow. The miss is gone.
I also was experiencing a tendency to die at idle when I came off hard acceleration. THis is gone too. She deffenitly has more power now without any money out of my pocket. Though if they loosen again I intend to buy new jam nuts.
Old Mar 13, 2010 | 10:39 PM
Harte3's Avatar
Harte3
Jam nuts...like in double nuts?
Old Mar 14, 2010 | 12:24 AM
flipklos's Avatar
flipklos
The nuts that secure the rocker arm are a self "locking" nut. Hence jam nuts. Double nuts are just that. Double nuts.
Old Mar 14, 2010 | 01:10 AM
Harte3's Avatar
Harte3
Some call the double nuts "jam" nuts...that is why I asked. If they won't hold you might try double nuts.
Old Mar 14, 2010 | 01:13 AM
flipklos's Avatar
flipklos
Napa sells the real deal. I find it odd that my lifters have to be maxed out with only about 35k on them.
Old Mar 14, 2010 | 02:09 PM
johnboy427's Avatar
johnboy427
Are you still running the pressed in studs? They are known for pulling out and messing up your valve lash, and if your cam is a little bigger than stock this is likely.
-John
Old Mar 15, 2010 | 12:31 AM
flipklos's Avatar
flipklos
Yes, I am. What is the remedy?
Old Mar 15, 2010 | 03:01 AM
johnboy427's Avatar
johnboy427
The one motor I put together that had this problem I just had screw in studs put in. I think this is the normal fix as my 79 parts truck has screw in studs as well because of studs pulling out according to the previous owner. You can check them by laying a straight edge across them, and if one is high the it won't lay flat across all of them.
-John
Old Mar 15, 2010 | 05:32 PM
Harte3's Avatar
Harte3
Some engine re-builders routinely install screw-in studs as part of the deal. Saves problems later on.
mustang81
Jan 6, 2014 01:13 PM
AndysFords
Aug 25, 2010 10:37 PM
ScottInTexas
Jun 12, 2007 05:42 AM
highrider76
Apr 30, 2005 06:14 PM
unioncreek
Mar 3, 2002 04:53 PM
