How long will it take someone to do an EGR delete kit?
Old 03-10-2010, 08:46 AM
texans's Avatar
texans
texans is offline
Block off and delete have the same result, but IMO delete is way better you won't have to worry about it again. With the block off there is always a chance of the plug going bad then you have the same problem again.
rickatic's Avatar
rickatic
rickatic is offline
Blocking off the egr cooler means blocking the flow of exhaust gases from the y pipe into the egr cooler. This has been used successfully by some on newer, low mileage trucks because it minimizes the temperature extremes seen by the egr cooler. The theory is less heating and cooling swings and thermal metal expansion/contraction cycles will enable the egr cooler to live longer. The delete is just that. EGR cooler is gone, no place for coolant to flow therefore no place for it to leak into the intake. I did my delete with a FCD kit and have a spare intake manifold. I am preparing for the possible smog inspections by by welding both ends of the egr cooler shut, pressure testing the welded vessel and setting on the shelf. If I need to return to stock look, I will install it.
Old 03-10-2010, 09:33 AM
ELVIS RANCH's Avatar
ELVIS RANCH
ELVIS RANCH is offline
Hi Cheezit, New here and looking for a little info. on changing the 2 serpentine belts on my King Ranch. There is a wire/line that runs between the fan and the rad. How do you get that apart to get the belts past?
Couldn't find any info. on the belts but just did an EGR delete and found you on the posts.Thanks, Jim
Old 03-10-2010, 09:51 AM
strokingbeast's Avatar
strokingbeast
strokingbeast is offline
This is the kit we have done Ford Products
they say you can reuse the gaskets but we have purchased new gaskets, esp. the one oil feed to the top of the turbo
Old 03-10-2010, 11:07 AM
ELVIS RANCH
I installed the Liberator kit on the weekend. Took me a little longer than the 4-6 hours the instructions say. I am looking for info on how to change the serpentine belts. I couldn't find any posts for this, so I may be in the wrong place.
Old 03-10-2010, 11:16 AM
ehgeeray's Avatar
ehgeeray
ehgeeray is offline
The easiest way to do it is to pull the radiator and fan/shroud assembly. At this point the belt is exposed and can be changed. You can't get the belt off without removing the fan/shroud assembly
Old 03-10-2010, 11:20 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
02GrayPowerStroke is offline
That kit looks good. Kinda hard to swallow the price tag though. Can you send me the instructions on it?
Old 03-10-2010, 12:10 PM
strokingbeast
the instructions are great for that kit. The price tag is a little big but includes shipping i believe and can call them for any tech questions
Old 03-10-2010, 02:37 PM
02GrayPowerStroke
Did the kit completly remove the EGR system all together?
Old 03-10-2010, 03:57 PM
strokingbeast
Yes i believe so.
Old 03-10-2010, 03:58 PM
02GrayPowerStroke
Yes i believe so.
Thanks for the reply.
Old 03-10-2010, 05:33 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Lubbockguy1979 is offline
I am waiting on a guy to tig weld a egr cooler for me. Seemed the most cost effective way to go. Weld up both ends. No place for it to leak.
  #28
Old 03-10-2010, 05:36 PM
1_BIGMOFO's Avatar
1_BIGMOFO
1_BIGMOFO is offline
dosent the intake piece get welded and the cooler get deleted?
  #29
Old 03-10-2010, 09:08 PM
strokingbeast
the intake just gets a block off and the then theres is a strait piece of pipe that attaches to the Y pipe
  #30
Old 03-11-2010, 08:18 AM
1_BIGMOFO's Avatar
1_BIGMOFO
dosent that straight pipe delete the EGR cooler itself?
Quick Reply: How long will it take someone to do an EGR delete kit?
