93 4.9L Idle and Hot Start Issues
I know there are a lot of these idle surging posts on here already. After searching for 2 hours I cannot find someone with exactly the same symptoms as me.
I have a 93 E150 4.9L with 189K that has driveability issues. The van will cold start just fine, but once you start driving and give it a normal amount of throttle from a stop it almost dies. The other issue is that after driving around it will not restart until it cools down.
Thing I've done:
Replaced the IAC
Replaced the TPS
Verified that the FPR isnt bad by applying vaccum.
Van has spark when it won't restart (doesnt mean the PIP isnt bad)
Fuel pressure=Key on engine off 55-60 psi, Key on engine on 50-55psi
Coolant temp sensor appears to be working as the gauge needle does move.
I havnt taken the throttle body off yet to clean it but being a van that is a chore and a half. This happened overnight so I'm inclined to believe it fuel related, but the fuel pressure seems to be within spec.
If anyone has any ideas I'd appreciate it.
Thing I've done:
Replaced the IAC
Replaced the TPS
Thing I've done:
Replaced the IAC
Replaced the TPS
Thing I've done:
Replaced the IAC
Replaced the TPS
And what brands did you replace the IAC and TPS with?
the gauge is a different sending unit than the one thats on the thermostat housing. the one on the housing could theoretically say its -40 all the time and the dash could be fine. the one on the dash is taken off one on the rear part of the motor. is your ignition module OEM?
IAC and TPS are both standard brand. I kept the originals just in case.
I would say before throwing more parts at it pull the codes and write them down so you have them.
I think I would then clear all the codes and drive it a bit so it can reload codes and see what they are.
Are any of them the same as before clearing them?
With the new codes you repair from the first to the last as you may do the first say 2 code repairs and the rest may clear.
Let us know what the codes are before and after clearing.
Dave ----
She is 100% right the computer gets its cold / hot information from the sensor at the stat housing not the same one the gauge uses.
Dave ----
Dave ----
Active:
116: engine coolant temp sensor incorrect signal
636: Transmission fluid TFT signal highlow
History: 118: Engine coolant temp sensor above maximum value
It would seem to me that the temp sensor in thermostat housing is bad. Out of curiosity do you know where the gauge temp sensor is located?
TY
So after letting it warm up I pulled the KOEO codes.
Active:
TY
Active:
TY
Actron
Inova
The innova is nice because it gives you a digital readout of the codes despite the source being an analog signal.
Active:
TY
Active:
TY
You may be able to access the gauge sender from your doghouse in an E150 (god I would hope so) but that doesnt seem to be an issue on your van.
since coolant temp sensors DO go bad with age and yours is likely OE, I Think a new one is in order. They are cheap and yours is very accessible especially for a part on a van.
So looking at it, your 116 and 118 could be explained by a bad ECT easily. Can you send a picture of your ECT? To my understanding ford replaced the connector design and you may not have the ability to find an ECT With the same connector as your van has.
I did find the temp gauge sensor (first picture) The other three are the other sensor in the thermostat housing. Im almost positive that the T stat sensor is bad because it measures open with a Ohm meter.
That should fix a majority of your issues. Once you do that you can turn your attention to the transmission temp sensor
Figured I owe you an update. Got the new sensor wired in and it runs much better and restarts when warm. Crazy how many systems that one sensor was hosing up.
Appreciate all your help.
The following users liked this post:
jshardy
13
08-11-2022 12:16 PM
ridetrains
56
11-10-2021 11:51 PM
jeffreyclay
17
07-11-2018 08:54 AM
