how to get better gas mileage out of a 7.5 460 - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 03-11-2017, 11:10 AM
ciamcoop ciamcoop is offline
ciamcoop is starting off with a positive reputation.
Quote:
Originally Posted by Fastback460 View Post
Yeah, I don't believe the hype of the great mpg's that diesels get.
A buddy of mine kept telling me he was getting over 25mpg with his 2010 Duramax . But when he actually calculated it, it was more like 13.
At that rate I think it will be cheaper to keep my 460 in the long run.
I've had a few Cummings diesels. A 93, 00, 07. They were powerful and got better mileage than my 460, but they never got consistently 20 mpg. Average was about 16 around town and 18-20 on the freeway depending on how fast I was driving. The fuel savings doesn't offset the purchase price and maintenance costs.
  #32
Old 03-11-2017, 12:44 PM
78 PEB's Avatar
78 PEB 78 PEB is offline
78 PEB is gaining momentum as a positive member of FTE.
A tow chain between it and a Geo Metro with the Geo in front????? LOL.....it's a 460........never gonna get much for mileage out of it........my '97 F-Superduty Quigley with a ZF5 and 5:13 gears gets 7MPG......loaded, empty, up hill or down hill......doesn't matter......7 is as good as it gets.......LOL But it will pull anything I hook it to........
  #33
Old 03-13-2017, 10:51 AM
raystankewitz's Avatar
raystankewitz raystankewitz is online now
raystankewitz is gaining momentum as a positive member of FTE.raystankewitz is gaining momentum as a positive member of FTE.
My '97 F250HD gets 12-ish on the freeway if I set the speed control at 65 and keep my feet away from the gas and brake. That's empty or full to the top of the bed with camping gear.
Around town, stop and go traffic, it's single digits, baby. 9-ish, give or take a 1/2 mpg.
Oh well . . .
  #34
Old 03-13-2017, 09:52 PM
BS51993's Avatar
BS51993 BS51993 is offline
BS51993 is starting off with a positive reputation.
20-25MPG is over exaggerated, I'd say 15-18 at the most. There are some aftermarket things that can be done to help the engine run cooler. The hotter the engine, the more gas it consumes along with losing horsepower. LMC truck sells an underhood heat shield that helps absorb heat under the hood resulting is cooler temps. Another thing to do is aftermarket exhaust. The factory exhaust system restricts backflow which also causes a decrease in fuel mileage.
  #35
Old 03-13-2017, 10:03 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Ha ha ha ha ha..
Fuel efficient 460....
Just forget about high teens and be happy with double digits.
If I saw 13 on the regular I'd be so happy I'd pi$$ myself.
for the poster above.
"Heat IS horsepower" go see who said that...
Adding an insulating blanket is not going to 'help your engine run cooler'
Back pressure IS an exhaust restriction. So one is not creating the other.
  #36
Old 03-13-2017, 10:08 PM
Caleb Ryan Caleb Ryan is offline
Caleb Ryan is starting off with a positive reputation.
To contribute tho it's of no help.
I have a 90 f150 5.8 with e4od.
With it loaded with 600LBs and healthy tires I got 18-20 on the top half of the tank until I ran into this no start and tranny bs. Thanks to my idiot *** and abuse.
  #37
Old 03-13-2017, 11:26 PM
fordka's Avatar
fordka fordka is offline
fordka is gaining momentum as a positive member of FTE.
I get about 300-325 miles to both my tanks in my 95 f350 460 5spd. Not each tank. Both
  #38
Old 03-17-2017, 09:05 PM
chrismd188's Avatar
chrismd188 chrismd188 is offline
chrismd188 is gaining momentum as a positive member of FTE.
with my 96 ccsb i get 7-8 in town and 10 highway
with about 4,000 miles on rebuilt motor
  #39
Old 07-12-2017, 01:18 PM
j66b j66b is offline
j66b is starting off with a positive reputation.
Doubling the mileage in a 460
If you search the site for,"fuel economy ford 460", in the resulting list there is a thread,"don't laugh...." Look at my post from today 7/12/17. I get an honest 16.5 at 65mph in an 84 F250. My post will tell you exactly what I did.
j66b
  #40
Old 07-13-2017, 12:52 AM
abranz abranz is offline
abranz is starting off with a positive reputation.
My 92 4x4 extra cab gets an honest 10mpg and that's after the engine rebuild. I've done the diesel thing which was a very expensive lesson with a 06 dodge Cummins. It was by far the most expensive vehicle I've ever operated over a five yr period due to fuel related issues. With the amount we spent on bad injectors and high pressure pumps which failed due to bad fuel according to dodge I can drive my 460 the rest of my life. Best of all no payments and I can repair most of the truck.
  #41
Old 07-13-2017, 06:34 AM
mrollings53's Avatar
mrollings53 mrollings53 is online now
mrollings53 is gaining momentum as a positive member of FTE.
Quote:
j66b
What you did to your truck may have gotten you better gas mileage, but these are ninth generation trucks. 1987 was the only year for a carbureted 460. 1988 and newer 460's are all fuel injected. A fuel injected 460 wouldn't even run with those modifications.
Swapping a F350 460 7.5L into a F250 460. 7.5L Hazlett Engine Swaps 4 07-22-2017 11:53 AM
Duramilage performance module MAD 6.7L Power Stroke Diesel 4 06-25-2017 05:24 PM
Best tuner for a 6.2 john hardy 1999 to 2016 Super Duty 2 11-22-2016 12:59 PM
1968 Ford F100 gear ratios demonkiller3418 1967 - 1972 F-100 & Larger F-Series Trucks 3 04-23-2016 11:12 PM
Mpg 7.5l 460 Paint_burner Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 40 03-10-2016 08:49 PM
Tags
1993, 1997, 2010, 460, 75, 96, f250, f350, ford, fords, fuel, gas, improve, milage, mileage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
