2004 codes
Old 01-23-2013, 11:02 PM
95_Dually's Avatar
95_Dually
95_Dually is offline
2004 codes
I connected a scanner and pulled two codes.
1) p0401
2) p0277
I cleaned the EGR valve about a month ago but the truck has 230,00 miles on it.
This forum helped me isolate the no start problem last month .... It was low voltage on the FICM. I had it repaired and it was running great. I checked the batteries:battery voltage and it is 12.5 volts.
The truck isn't running right at all, seems like a misfire.
Hoping for your help again.
Old 01-24-2013, 12:33 AM
dannyboy950's Avatar
dannyboy950
dannyboy950 is offline
p0277 #6 injector circuit high. FICM detected a short to ground or a defective coil
p0401 Egr insufficient flow EGR valve position does not match desired limits based on engine speed and load.
EGR sticking egr sensor biased [bad] Ep sensor biased
re-clean egr valve check wires to #6 injector or change injector if no wire problem found
Old 01-24-2013, 11:30 PM
95_Dually's Avatar
95_Dually
Thank you for your reply
ravens fan
03-21-2013 08:26 AM
wvmike
Modular V10 (6.8l)
10-09-2008 11:26 AM
theguy_88
1999 to 2016 Super Duty
01-01-2008 12:41 PM
92F150Flare
08-08-2007 05:03 PM
Kallie
03-24-2007 02:43 PM
Quick Reply: 2004 codes
