Engine identification
462 CID ENGINE BLOCK CASTING NUMBERS:
C6VY-A........1966-68
C6VE-A........1966-68
C6V..............1966-68
462 CYLINDER HEAD CASTING NUMBERS:
C6VE-A....1966-68
C6VE-B.....1966-68
C6VE-D....1966-68
C6VE-A....1966-68
C6VE-B.....1966-68
C6VE-D....1966-68
Maybe it will help you out.
EDIT: Also you may find some block numbers on the block somewhere. Also read on the history of this unit and it was a good read.
The distributor appears to be from a 1977 and later V8 and was only used w/DuraSpark Electronic Ignition.
There is what appears to be an oil cap on the left valve cover, that didn't occur until 1965 on V8's.
M-E-L's were 1958/67 383/430/462's.
Count the number of valve cover bolt holes per side. I believe MEL's have 6.
http://ford-mel-engine.com/viewtopic.php?f=3&t=172
And there is a top view here of a C6 with the ribbing I see in the pics:
http://www.crankshaftcoalition.com/w...identification
IIRC looks like a C6 behind a 460. Count those valve cover bolts....
Thanks guys for helping me out.
I found some pictures on ebay of a mel462 with a C6 trans.
LINCOLN 462 MEL 7.6L V8 ENGINE AND C6 TRANSMISSION 1966 : eBay Motors (item 170454628576 end time Apr-03-10 11:51:35 PDT)
The engine really looks the same as the one in the car. The valve covers are indeed hold by 6 bolts.
I will count the valve cover bolts tommorow and let you all know.
We have a positive ID on the engine.
It's a Ford 460
Here are the codes we found:
engine: D1VE A2B
intake: D3VE A1B
heads: D3VE A2A
Thanks guys for helping out.
More info on the car@
Project Salt Shaker - Ford Truck Enthusiasts Forums
It's a Ford 460
engine: D1VE A2B
intake: D3VE A1B
heads: D3VE A2A
northerndave
06-11-2012 08:23 PM
sportfuryjoe
21
07-13-2011 03:57 PM
1966, 462, bb, distributor, engine, f150, find, ford, idenificaction, identification, lincoln, motor, number, picture, truck
