05 eddie bower manual?
sad and happy all at the same time.the wife went and traded in my chevy silverado 1500 4x4 for a 05 expadition(eddy model) i beleave its a 5.4 triton v8 with some sdc track controll lingo on the back.nice ride leather cold air total mommas ride for sure.anyone have a pdf file of a owners manuel for this truck? it did not come with one and i have a few issues with it allready.its about 6 hours old in my driveway.tryed to put in a cd for the kids in the rear dvd thing and it wont take disc.tryed to use the navigation systom and it ask for a disk? kinda confused about the drive terain systom also.awd mode?on dash plus a push butten deal at the console? i need a read on this ride/ kinda new hear but have been liveing in the super duty fourm untill now.any help?
Change the 3 drop down boxes to select your information.
https://www.fleet.ford.com/maintenan...ls/default.asp
You don't have AWD (all wheel drive) you have A4WD (automatic 4 wheel drive). When A4WD is selected the vehicle will automatically shift into 4WD if wheel slip conditions are met. It will then revert back to 2WD. It is a momentary activation of 4H. I keep both of mine in that mode all the time, others will tell you not to because mileage and part wear will be effected. I've got almost 170k on one of them and I haven't worn anything out yet. The only time I take it out and go to 2WD is to hang the back end out in the dirt.
You also don't have traction control, you have AdvanceTrac with Roll Stability Control. Traction control is not available with this feature. RSC is way more than traction control - it monitors yaw and roll to detect impending roll over and makes power and braking corrections to (hopefully) prevent it. It does handle the traction control duties as well so you aren't without that and it saves you having to service chattering LSD clutch packs every 30k miles.
Long story short, leave it in A4WD and the traction control on (it is on by default)
johnkn
05-12-2013 05:55 PM
